How to use unimplemented opcode trap interrupt in HC12 ?
shebo
Member level 2
do you ever care?
about HC12 Assmebly?
how can i use unimplemented opcode trap interrupt in HC12 (using assembly)?
Re: about HC12 Assmebly?
in many cases for example in expansion memory mode when u connect memory to MIcrocontroller thorugh(program window) so program counter go there and excute the code there if u put data there not opcodes so the interrupt will happen
    shebo
