How to use the interrupt in PIC84A using MikroC?
benze
Newbie level 5
Philippines
hello Frends,
im making a project that will communicate between 1 pic877a and 2 pic84a and will control 2 motors, and im using mikroc programming. My problem is how to make use interrupt in my pic84a the time my 877a will command my 2 pic84a? bcoz in the code of my 84a there is a looping part that delay the signal in order to vary the speed of the motor. How to use interrupt in mikroc in my 84a if the 84a is reading in the loop part of the code and the 877a is sending signal to 84a? bcoz f there is no interrupt it is possible that my 84a cannot read the signal sent by 877a if the process of 84a is
in the looping part of the codes. hope you go it what im trying to explain.
tnx alot.
