How to use SG3525 to convert dc to pure sine wave?
helenfish
Newbie level 3
sg3525 sine wave
hello:D
i am doing my design project now. i have some problems on using this IC. could anyone give some informations or ideas to me? thanks!
how to use sg3525
The output from this IC is a square wave, so if possible use ICs which can generate sine waves, for example MAX038 ..
However, there is another option ..
If the output frequency doesn't change much you can consider a multi-pole passive/active filter connected to the SG3525 output .. This filter should filter out most of higher harmonics and the resultant wave will be "almost" sine wave ..
Regards,
IanP
conversion dc to sine wave
thanks for ur reply. i will try to check the datasheet of MAX038 first:D
