how to use sdf file in NC-verilog?
peen1
Member level 2
ncverilog sdf
I have these followng files
test.sdf
a.v,
testbench.v
The testbench.v file instantiates a and test. Everything compile in Nc-launch/verilog and I also get test.sdf.X file but during ncelab it says can't find design test. Also it does not produce a snapshot for simulation.
I have saved test.v in a seperate location and do not compile that.
Does anyone know how to use sdf files in nc-verilog simulation?
Thanks
ncvlog: +sdf
SDF attached in the test bench
initial $sdf_annotate ("test.sdf",<instance of a module>);
nc verilog sdf
hi
u try with this.
in the initial block of test bench write this
initial
begin
$sdf_annotate("/path of sdf.x file",u0);
