How to use PSS analysis in Spectre?
yxo
Full Member level 4
The Netherlands, Delft
I need simulate AC for SC- S/H
How use PSS analysys in spectre? I do not understand parameters. Explain me pls. Or may be some tutorials? Thanks a lot.
gunturikishore
Full Member level 2
INDIA GANDHINAGAR
Re: PSS analysys
Tell me the parameters you require to set. I can suggest you if you tell me your circuit periodic conditions and small and large signals in your circuit.
yxo
Full Member level 4
PSS analysys
S/H is simulated for pipeline ADC. It is contolled by 4 phase clocks + 1 clk. Also S/H include fully dif amplifier with CMFB on SC. I want to know ac response of my S/H. Before I tuned output of CMFB to get essential output common mode voltage and used simple ac analysys (but it is only for amplifier and is not precisly)
