How to use powerpcb 4.0 to open a powerpcb 5.0 file ?
adolfchen
Member level 1
Member level 1
open power pcb files
thx!
powerpcb 5 demo
Hi adolfchen,
you must use command File-Export - ASCII- Format and select what version you want. This ascii file you can import.
:D JURS
powerpcb 5.0
Also dont forget to set asc version to 4 !! when exporting
powerpcb demo
import de .asc file
powerpcb how to open
If I only have the pcb file of powerpcb5.0, how to open it?
If you get the PowerPCB 5 demo, you should be at least able to view it on the screen -- but I guess you want to save it.
I do not know any way around the issue without having access to a fully functionall PowerPCB 5 if you want to convert the design. :?
good luck
Ted
thank for everyone, I have understanded how to do.
