how to use % operator in verilog
taolibuyan
Newbie level 3
verilog modulo operator
I got this error "Operator % is only supported when the second operand is a power of 2." My second operand is a integer constant. Is it synthesizable? I have to use this operator.
modulo operator verilog
What tool is giving you this error? How are you using the modulus operator?
verilog modulus operator %
Many synthesis tools don't support integer division/modulus/remainder unless the calculation is trivial, such as division by a power of two. If your value isn't a power of two, then you are probably out of luck.
Maybe you can use another approach such as building your own math module, or using a math core from your software's IP library.
Or maybe you can approximate the division by multiplying by the fraction 1/K instead of dividing by K.
If both operands are small, you could fetch the result from a ROM lookup table.
verilog mod operator
Xilinx ISE 8.1
My codes are simply
if (A % B > ***)
Added after 5 minutes:
Thanks. It seems it's impossible to use modulus/division operators. :(
The range of my operands is too large for a lookup table. I will try math core.
Re: verilog modulo operator
It's not synthesizable is your second operand is not 2.
you need design by hand.
Re: modulo operator verilog
Hi, i want to make a verilog module that calculates (A mod B) where b is 31, the result remains between 0 to 31 whatever the input A is,,, any help in this regard would be appreciated.. i am using xilinix ise 14.1..
Shouldn't this be A mod 32? Which the results will lie in the 0 to 31 range? If so this should be synthesizable.
-alan
If you are not worried of accuracy you can do the modulo operation in verilog synthesizable by following math operation
x mod k
1.Calculate 1/k and then multiple with a number which is in power of two like 32,64,256.....
2.Multiply the resultant value with x and then divide by the power of 2 number that is been used for division
There is bug in xilinx tool
Modulo will be synthesizable when (x mod k) -> x is signal not variable.
ofc k dont need to be the power of 2. Somehow synthesis tool requires k to be power of 2 when x is variable.
You can check it in some paper -> xilinx design recommendation or sth. The recommandation for counters to MAX_VALUE value is
cnt <= (cnt+1) mod MAX_VALUE
Thats understandable - its preventing the generating of the massive logic required for the mod operation.
Basically, the mod or % operator is pretty useless in synthesisable HDL, as the fmax would be rather slow.
When K is constant xilinx sythesis handle is very well with resourses usage twice less then altera and very good fmax. But in Altera, quartus uses lmp_div cores and u get sloppy design. So i stopped using modulos after all, because all in all imho quartus is far better enviroment (maybe except modulo implementation)
