You must build your verilog PLI 1st, check the pdf file in $Debussy_Dir\share\PLI
But unfortunately you may need to midify the makefile if you uses visual c++ as compiler.
I attached the pdf doc as your reference.
(README for PLI)
I follow the step.
1.copy makefile.nc ,..
2. set environment variable ARCH=wint
3. modified makefile.nc as it said
4. modified makefile.nc.wint
5 do make -f makefile.nc
but it show" Error makeile.nc 2: command syntax error
Error makeile.nc 5: command syntax error
Error makeile.nc 302: command syntax error
*** 3 errors during make ***
