How to use malloc( ) and free( ) in PICC?
kerden
Junior Member level 3
pic malloc
I have writed a simple program like this:
#include<stdlib.h>
void main(void)
unsigned char *ptr;
ptr = (unsigned char *) malloc(sizeof(unsigned char));
free(ptr);
This just used to test how to use malloc() and free() in PICC.But after compiled,some error message appear:
Error[000] : undefined symbols:
Error[000] : _free (D:\MPLAB IDE\PICproject\Test\test.obj)
Error[000] : _malloc (D:\MPLAB IDE\PICproject\Test\test.obj)
I have doubt in why these error message appear.How to do dynamic memory's program such use malloc() and free() in PICC?
Best regards,
malloc pic
To use malloc() and free() you need to include stdlib.h
Regards.
pic18f malloc
Regards.
yes !
i have included stdlib.h
pic18 malloc
Ho sorry, I don't know why, my browser didn't show me the <stdlib.h>....
I've tested your code on my mplab with picc18 and it's work. May be you have a problem with your library installation....I don't think picc and picc18 are different when using free() and malloc().
mcc18 malloc
I think it has no heap space in pic mircocontroller.
but malloc() and free() are used to control heap in personal computer.
I think the reason is from PIC compiler
hi-tech malloc
thank you very much.
i ve also tested my code with picc and picc18,but i doesn't work.are you picc18 is a demo? where have you downloaded?
malloc et pic
My picc18 it's not a demo....but I think your code could work with a demo version. Try to put stdlib.h in the directory of your simple program and put #include "stdlib.h" instead.
malloc() mcc18
i have copy the stdlib.h under the project file.but it doesn't work;
some error as follow
The target "D:\picc\PIC18\fgh.obj" is already up to date.
Executing: "C:\HTSOFT\PIC18\BIN\PICC18.EXE" -E"2.lde" "D:\picc\PIC18\fgh.obj" -M"2.map" -O"2.cof" -O"2.hex" -Q -MPLAB -18F248
Error[000] : _free (D:\picc\PIC18\fgh.obj)
Error[000] : _malloc (D:\picc\PIC18\fgh.obj)
Error[000] D:\picc\PIC18\fgh.obj 17 : Fixup overflow in expression (loc 0x20 (0x1C+4), size 1, value 0x100)
Error[000] D:\picc\PIC18\fgh.obj 17 : Fixup overflow in expression (loc 0x22 (0x1C+6), size 1, value 0x101)
Error[000] fgh.rlf 24 : Fixup overflow in expression (loc 0x1 (0x1+0), size 1, value 0x100)
Error[000] fgh.rlf 28 : Fixup overflow in expression (loc 0x1 (0x1+0), size 1, value 0x101)
BUILD FAILED: Fri Mar 24 18:59:03 2006
malloc mcc18
If you look at the application notes on Microchip website you will find some c code for dynamic allocation of Ram using homebrewed malloc and free. You have to modify the linker file to get some heap memory from which to allocate and free ram.
I am using my own version of it for a linked list and it works just fine.
I am using Microchips Mcc18 compiler for the 18 series. I much prefer it to Hi-Tech.
Hi-Tech is ok for the low end 16 series
