How to use 'LN' and 'EXP' in C language
rizalafande
Junior Member level 2
ln function in c
Can anyone helps me to show how to use 'LN' and 'EXP' mathematical operations in C language? I have tried using below codes but unfortunately doesn't work.
#include <math.h>
double x (double enter)
double exit;
exit = ln(enter) + exp(enter);
FvM
Super Moderator
Staff member
Bochum, Germany
how to use ln
The usual function name for natural logarithm is log(). But you have to check if it's implemented with your compiler's math.lib.
dhenzite
Newbie level 3
ln in c code
/* Reverse polish notation calculator. */
#define YYSTYPE double
#include <math.h>
%token NUM
%% /* Grammar rules and actions follow */
The C declarations section (see section The C Declarations Section) contains two preprocessor directives.
The #define directive defines the macro YYSTYPE, thus specifying the C data type for semantic values of both tokens and groupings (see section Data Types of Semantic Values). The Bison parser will use whatever type YYSTYPE is defined as; if you don't define it, int is the default. Because we specify double, each token and each expression has an associated value, which is a floating point number.
The #include directive is used to declare the exponentiation function pow.
The second section, Bison declarations, provides information to Bison about the token types (see section The Bison Declarations Section). Each terminal symbol that is not a single-character literal must be declared here. (Single-character literals normally don't need to be declared.) In this example, all the arithmetic operators are designated by single-character literals, so the only terminal symbol that needs to be declared is NUM, the token type for numeric constants.
jhbbunch
Full Member level 4
exp c language
Don't use names like enter. It looks like a programming word and is confusing.
Secondly, exit looks like a programming word also, and it is, it is a reserved word. You can't use it as a variable. You must use return(log(enter) + exp(enter));.
Lastly math.h uses log for the natural logarithm and log10 for base 10 logs.
FvM
Super Moderator
Staff member
Bochum, Germany
c ln function
I agree, that misleading variable names should be avoided, but actually none of the said variable names is a reserved word in standard C. So there's no error to correct, just a matter of taste.
Apart from using a wrong function name for log(), as I already mentioned, the function returns no value.
jhbbunch
Full Member level 4
c language ln
Good catch, you're right, exit() is not a reserved word but it is a function defined in stdlib.h, and is a very commonly called function. I used to automatically include stdlib.h in anything I wrote, so exit was about as good as a reserved word.
rizalafande
ln in c language
thanks to all the feedback. problems now have been resolved.
FvM
Super Moderator
Staff member
Bochum, Germany
ln function c
As I already said, I wouldn't use it as a variable name, because it's a source of confusion. But even if you include stdlib.h, the variable definition overloads the function prototype and thus can be used without any problem.
