How to use If...Else statement to compare struct's
vead
Full Member level 5
Full Member level 5
india
Hello everyone
I want to compare current date with Alarm dates which is in dd/MM/YYYY string format
This is the data structure that is used to store the current date
Code C - [expand]
typedef struct  {
    int day;
    int month;
    int year;
} Date ;
This is the data structure that is used to store the Alarm date
Code C - [expand]
typedef struct  {
    int day;
    int month;
    int year;
} Alarm_Date ;
Start function
Code C - [expand]
int main ()
Current date : 01/10/2015
Alarm dates :02/10/2015, 04/10/2015, 06/10/2015
Compare current date with alarm date
If current date match with Alarm date 02/10/2015, than compare next Alarm date
If current date match with Alarm date 04/10/2015, than compare next Alarm date
If current date match with Alarm date 06/10/2015, than compare next Alarm date
How to use If...Else statement to compare current date with Alarm date ?
Re: How to use If...Else statement to perform the comparison.
Structure is an array of bytes in memory. So, easiest way is to compare them like a string.
your both typedef have same members so no need to define them twice..
rather....
Code C - [expand]
8
typedef struct
uint8_t day,
uint8_t month,
uint8_t year,
}_tdt;
_tdt Date,AlarmDate;
there is a library function (if your compiler supports) memcmp...
search about it...
Use the 'strcmp(first string,second string)' command, it returns zero when the two strings are the same.
Brian.
I presume, the code author has a reason to use binary records rather than strings to represent the date information, I would also do so. In this case you can use memcmp() to compare the complete records.
