owen_li
Full Member level 3
internal_pins
When I implemented my scan chains in DFT Compiler. I used the internal_pins flow. For instance, I use the set_dft_signal -hook_pins to control the test reset signal. However, When I completed the insertion of the scan chains, the dft_drc command reported a vatal erro saying that the scan cell cann't be reseted to a known state.
I want to know how to use the dft_drc command in the internal_pins flow within DFT compiler. thank you!!
