Ahmed Ragab said:Well I used this idea before ,.. and i guess it will work good enough on any micrcontroller
1-let the alarm sensor trigger an interrupt to the micrcontroller ...
2-this interrupt may itself trigger the timer or counter in the controller to work.
3- adjust the counter u use to enable the alarm circuit u got
The only thing you will need is to calculate the value the counter will trigger the alarm after .. this will depend on the crystal frequency you use
sztibi82 said:It depneds about the micorcontroller which you use and alos about the frequesncy.
Check
h**p://www.boondog.com/%5Ctutorials%5Cpic16F84%5Cpic16f84.html#timer1_0
