ssc987
hi,
i'm using EDK12.4 to develop an Embedded design. The minimum frequency that microblaze can be given is 50MHz. I'm using viretx-5 ML506 boadr frequency of 100MHz. For my system design i need a frequency of 3MHz. I tried using the clock generator IP with a dedicated dcm module. It is giving the error issued from TCL procedure CLKOUT0 can not be generated (with CLKBOUT) alone from the clock input. The clock input to the clock generator is system_clk_50MHz.
can somebody please help me with the exact procedure to use a clock generator and the dcm module. Thanks a lot..
