May 8, 2010 #1 V vivek_p Advanced Member level 4 Joined Feb 16, 2010 Messages 115 Helped 10 Reputation 24 Reaction score 9 Trophy points 1,298 Activity points 2,009 I have generated a VCD file using Modelsim. I have read that VCD file gives the switching activity. How can I use this VCD file in Synopsys to calculate the power consumption. Can anyone help me? If possible can anyone provide a step by step procedure...
May 8, 2010 #2 L ljxpjpjljx Advanced Member level 3 Joined May 5, 2008 Messages 968 Helped 80 Reputation 162 Reaction score 56 Trophy points 1,308 Location Shang Hai Activity points 4,679 Re: VCD file the flow may be very crasy! need someone to explain!
May 9, 2010 #3 V vivek_p Advanced Member level 4 Joined Feb 16, 2010 Messages 115 Helped 10 Reputation 24 Reaction score 9 Trophy points 1,298 Activity points 2,009 Re: VCD file Can anyone explain
May 10, 2010 #4 L lund728 Newbie level 4 Joined Mar 27, 2009 Messages 6 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,315 VCD file If you use Nanosim as your power simulation tool, You may need .sig file which states all the inputs nodes (or outputs if they are included in your .vcd file). For Nanosim, you can check the useguide how it works.
Jul 7, 2010 #5 S sahara466 Newbie level 1 Joined Jul 7, 2010 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Iran Activity points 1,286 Re: VCD file In power compiler you can use vcd2saif command: vcd2saif -input /home/user/vcd_file.vcd -o backward saif_file.saif Then you can read the saif file and report the power: read_saif -input "/home/user/saif file" -instance DUT report_power -analysis_effort high > "report.report"
Jul 9, 2010 #6 itsmeteja Full Member level 2 Joined Feb 29, 2008 Messages 132 Helped 36 Reputation 98 Reaction score 21 Trophy points 1,298 Location Bangalore, India, India Activity points 2,086 Re: VCD file There are many tools available in the market. If you are using the synopsys tools you already have your answer. If you are using the cadence, they have solution using the powermeter. If you are using the sequence they are having the power theater soln. Let us know which tool you will be using in the flow.. some of us can answer you.
