How to understand this Bias Circuit?
isaacnewton
Full Member level 2
Earth Village
There are 3 branches in the this circuit. In order to get Equation (14) and (15). The currents through those 3 branches should be equal. I don't understand why the currents through the 3 branches are equal.
Which book did you get this figure?
It's from an IEEE paper:
Evolution of high-speed operational amplifier architectures
Smith, D. Koen, M. Witulski, A.F.
Burr-Brown Corp., Tucson, AZ, USA ;
This paper appears in: Solid-State Circuits, IEEE Journal of
Publication Date: Oct. 1994
Volume: 29 , Issue: 10
On page(s): 1166 - 1179
I think the current through 3 branches are not equal.
Assuming I1=first branch (current through Q2)
I2=2nd branch (current through Q3)
I3=3rd branch (current through Q7)
You can derive that:
I2*R + Vbe5 +I1R + Vbe2 = Vbe4 + Vbe3
Hence, Eq 14 = I1 + I2
Vbe4 + Vbe3 = Vbe7 +I3R6
Hence. Eq15 = I3
I1, I2 and I3 may not be equal, but the sum of Eq14 and Eq15 should give flat current over temperature, which is current flow through Q6.
    isaacnewton
Heres the explaination hope it can clear up some of your question
    isaacnewton
You are right. Thanks.
Do you know what's the point to put R2 there?
R2 serves as the one to produce the reference current in the second bias...
As you can see, between the bias lines is double differential pairs...
Hi
I think you need to read about TransLinear Circuits (Barrie Gilbert)
Or the book : The currrent mode approach
(Toumazou & Lidgey)
I don't understand gundam's explanation. In the equation you write why do you assume that current "I" goes through R1, R2, R6, and R5? Other strings also carry current...
Suppose I1 flows in the 1st string, I2 in second and I3 in 3rd. Then we have the following equations:
Vbe4+Vbe3=Vbe2+Vbe5+I1R3+I2R4
i.e. Vt ln(I1/A4 Is) + Vt ln(I2/A3 Is) = Vt ln(I1/ A2 Is) + Vt ln(I2/A Is) + (I1+I2) R
this gives us:
I1 + I2 = Vt/R Ln(A2 A5/A3 A4)
Also
I3 ≈ Vbe/R6 (Approximate)
Then we have (I1+I2+I3) (R1+R5) + Vbe1 + I1 R2 + Vbe3 + Vbe4 + Vbe6 = (Vcc-Vee)
None of these equations set the condition that I1 and I2 should be the same.
    isaacnewton
Many thanks for your sharing!
aryajur is correct, very excellent answer!
