how to understand "ac phase"
liucheng311
Junior Member level 3
China
hi,dear all
how to understand the parameter "ac phase" in VSIN in analoglib;i use it in the simulation for small signal analysis, should i assign "ac phase" 0 or 180??
could anyone help me?
Braski
Full Member level 3
Florence (ITALY)
assign 0 to phase and 1 to amplitude to have the transfer function at the output. if you give an AC phase different than 0, you will observe the transfer function shifted by that phase.
liucheng311
China
thank you for replying
i have another question:when i simulate the multiplying factor K in the equation VOUT=K*V1*V2(V1 and V2 are two terminals of the multiplier),i assign "ac phase" of one VSIN 0,the other 180.
what is wrong with this assigning??
enjunear
Advanced Member level 3
USA, midwest
At first look, it sounds like you are trying to use the multiplier as a signal combiner (mixer). If one signal is injected with a phase angle of 0 degrees, and the other is injected with a phase angle of 180 degrees, then your two signals cancel each other out. A*cos(θ+0) + A*cos(θ+180)... if θ=0, 360, etc, then A*cos(0) + A*cos(180) = A + (-A) = 0
If that's the case, try injecting on at 0 deg, and the other at 90 degrees. Then you should get a flat (DC) output signal vs. time.
A*cos(θ+0) + A*cos(θ+90) = A
More information about your circuit, simulation program, etc are needed to provide an accurate answer.
