[SOLVED] How to turn this Pseudo-code into something working?
RobertL
Newbie level 5
Newbie level 5
The Netherlands
I was looking for a program that is able to split up txt-files at given lines (e.g. lines that start with WORD or lines that have less than say 11 characters). The only programs I could find where programs that could split txt files by filesize, so I wrote 'my program' in pseudocode. The only problem is: I don't know how to get it working. I would like to have it run directly by opening the file, so something like a Batch-file or Java would be OK (those languages I understand a little). Can someone help me translating it? The coding is allready done. Off course, if you know an existing free program that has the same function, that's OK too.
%% variables:
NUMBER=1    % line number
XX=0        % new files get this number, e.g. file1.txt
while(NUMBER < length(source.txt))
    if(length(line(NUMBER)) < 11)
        check=1
    else
        if(check=1)    % the previous line was short and the current line is not
            XX++
            check=0
            (eventually there has to be created a new file sourceXX.txt with instead of XX a number. The name before XX (source in this case) has to stay the same as the original file (in this case 'source.txt'))
        end
        add a new line to sourceXX.txt (new line without overwriting others. XX is again a number)
    end
    NUMBER++    % go to next line
end
P.S.: My OS is Windows. source.txt can be in the same directory as this script.
Something like that, but the output should be in seperate new files.
Besides, is it hard to run C# code? How to ignite it?
check this routine it will create 20 new files for your sample file
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using System.Text.RegularExpressions;
namespace ConsoleApplication1
    class Program
        static void Main(string[] args)
            bool isNewFile =true;
            bool isFileClosed = true;
            int fileNum = 0;
            string outputFileName = String.Concat("C:\\output", fileNum, ".txt");
            StreamWriter SW = null;// new StreamWriter(outputFileName);
            string w;
            string line = "";
            using (StreamReader sr = new StreamReader("C:\\output.txt"))
                while ((line = sr.ReadLine()) != null)
                    w = line.Substring(0,10);// (sentence, @"\W");
                    if (w != "CHECKPOINT")
                        if (isNewFile)
                            fileNum++;
                            SW = new StreamWriter(outputFileName);
                            isNewFile = false;
                            isFileClosed = false;
                        SW.WriteLine(line);
                    else
                        isNewFile = true;
                        if (!isFileClosed)
                            SW.Close();
hope this help you
Here you may find the VS2005 (C# 2005) project files
  • ConsoleApplication1.zip
