How to transmit data, such as temperature, using RF TXD?
eehero
Full Member level 3
Libya
picaxe 08m tx433
my quesition is some how basiclly because i donot have a good background about this problem
so how to transmit data such as tempreature or any other using RF TXD
IanP
Advanced Member level 5
West Coast
picaxe rx433
All what you need is a temperature sensor, microcontroller with Analog-to-Digital converter and a serial por, and RF modem ..
Examples of components:
DS18B20 = temperature sensor
PICAXE-08M = microcontroller with A/D and serial port
(see picture below)
and
TX433/RX433 = 433MHz RF modules
"Wireless Radio Data Transfer with TX433 & RX433"
Regards,
IanP
eehero
Full Member level 3
Libya
Dtaa transmitting
thanks much ipan for fasting reply
and i am sorry for a syntax error of posting address dtaa=data!!!!!
eehero
Full Member level 3
Libya
Dtaa transmitting
ok
really my favorite Mc is atmel (8051 and avr)
but i wanna to ask about the output data of the RF transmitter is it analog or digital!! and how to deal with it using atmel microcontrollers (avr such as atmega32, at90s2313 or atmega8515)
IanP
West Coast
Re: Dtaa transmitting
These RF modules take data in serial format (same as RS-232) then use ASK modulation - see picture below - transmit modulated signal through RF channel and finally the receiver demodulates signal and outputs data again in serial format ..
From RF modules point of view there is no difference whether you use a PIC, AT, 8051 or anything elese .. The most important thing is to set both sides to the same baud rate, the same number of bits in a word (byte) and the same start/stop bit configuration ..
So, in your case, if you need to connect two 8051 using RF modules you will connect at one side microcontroller'sTX pin to the transmitter and at the other side the receiver's output will be connected to RX pin of the other microcontroller ..
Regads,
IanP
