rockey bhardwaj
Newbie level 1
- Joined
- Sep 6, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 20
Goodevening everyone
I am making an attendence system using 8051.But Id number is not displaying on the lcd. i am using the controller 8051. But I am fail to receive the data on lcd . If anyone know to display the data on lcd. Then please help me.
this is the code :
//Program to interface RFID with 8051 microcontroller (AT89C51)
#include<reg51.h>
unsigned int data_out,command=0x80,temp;
sfr lcd_data_pin=0xA0; //P2 port
sbit rs=P1^0; //Register select
sbit rw=P1^1; //Read/Write
sbit en=P1^2; //Enable pin
unsigned char card_id[12];
void delay(unsigned int count) //Function to provide delay
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1275;j++);
void lcd_command(unsigned char comm) //Lcd command funtion
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
void lcd_data(unsigned char disp) //Lcd data function
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
lcd_string(unsigned char *disp) //Function to send string
int x;
for(x=0;disp[x]!=0;x++)
lcd_data(disp[x]);
void lcd_ini() //Function to initialize the LCD
lcd_command(0x38);
delay(5);
lcd_command(0x0F);
delay(5);
lcd_command(0x80);
delay(5);
void recieve() //Function to recieve data serialy from RS232
unsigned char k;
for(k=0;k<12;k++)
while(RI==0);
card_id[k]=SBUF;
RI=0;
void main()
int l;
TMOD=0x20; //Enable Timer 1
TH1=0XFD;
SCON=0x50;
TR1=1; // Triggering Timer 1
lcd_ini();
lcd_command(0x81); //Place cursor to second position of first line
lcd_string("UNIQUE CARD ID:");
delay(200);
while(1)
recieve();
lcd_command(0xC1); //Place cursor to second position of second line
for(l=0;l<12;l++)
lcd_data(card_id[l]);
this is the code :
#include<reg51.h>
int i,j;
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
int x;
lcd_data(disp[x]);
lcd_command(0x38);
delay(5);
lcd_command(0x0F);
delay(5);
lcd_command(0x80);
delay(5);
unsigned char k;
for(k=0;k<12;k++)
while(RI==0);
card_id[k]=SBUF;
RI=0;
void main()
int l;
TH1=0XFD;
SCON=0x50;
lcd_ini();
delay(200);
while(1)
recieve();
for(l=0;l<12;l++)
