How to transmit ctrl-z at the end of string in C++?
DCO_81
Member level 1
Germany, south
generate a ctrl+z in c++
how can I cat "ctrl-z" at the end of a given string?
-----> strcat(string, [ctrl-z] );
I know that the hexcode is 0x1A but the 2nd argument have to be type of const char *. Is there a escape-sequence like \r or \n ?
ctrl-z escape sequence z
if you insist on using strcat you could create a char array
char ctrlZ[]={0x1A,0x00};
then you can use ctrlZ as the argument.
    DCO_81
transmit ctrl-z with c++
Afaik
\0xxx can be done in strings , but xxx has to be octal
/Bingo
