you arrange the L and C in parallell and put it in the output of your circuit.... this combination will only allow a signal of frequency 1/2Π(√LC) to pass through....
what type of modulation are you planning to use....
then you can go for active notch filter... they are generally high Q filters...
the Q of a filters decides how narrow banded the filters frequency response is....
it depends on which path you connect the output of the filter... if you ground the LC circuit part then it rejects that frequency and if you connect it to your required output then it passes that frequency to your required terminal...
depending on the selectivity you want, but you can simply use in parallel to your circuit output a serial L and C (f=1/(2Π√(LC)).That should ground your specific frequency.
What is your working frequency band?
