Re: test SPI with computer
Thank Alot,,,
but, is it for motorola only,, i have downloaded it ,,,but not working properly,,, are you sure i can use for other controller,,,,,,
usbiocom.dll,,,,,,error,,,,
how can i set up it ,,,and again, is there is no usb dongle needed,,,,,
Regards
Hasan
Added after 7 minutes:
hi Chris,
i set up it again, on XP this time not Vesta, its working fine so far, but i didnt make a parallel cable, for testing, yet,,,,,
if you knew it can work fine with other controller pls feed me back,,,,and i will do the same as soon as i finish the cable,
regards,
hasan
