[SOLVED] how to test PC parallel port
syeda amna
Full Member level 4
Pakistan
hi
how to test the parallel port of a computer.
I have faced a lot of trouble during parallel port interfacing. now i want to test whether my lpt port is ok or not.
how can I check whether it is working or not.
i am using Win Vista.
thanks.
srizbf
Advanced Member level 5
which compiler you use for your parallel port program ?
lockman_akim
Advanced Member level 1
Malaysia
this my freeware..u can use this software to check the output from the port..use multimeter to check wheter it have 5V or not at your pin..
  • LocX ParaCon.zip
srizbf
syeda amna wrote:
my program is written in C language.
if you use turboc then you can have access (16bit mode).
if you use visualc , then you should have appropriate rights for accessing the port.
hence the question.
nandhu015
India
hi
thanks.
Just connect a printer and print a page, if it is ok then your printer port is fine else the printer will show error
syeda amna
Full Member level 4
Pakistan
Thanks for your replies.
i don't have parallel port printer.
i will try this.
