[SOLVED] How to tell the synthesis tool to use a specific gate
S
somu.atluri
im synthesizing a code, and I want the tool to make use of 3-input gates...
but the tool is synthesizing with 2-input gates and inverters.
is there any command for RTL compiler to constrain and use 3-input gates.
Thanks in advance.
Hi Somu,
Answer is pretty simple...Put set_dont_use on 3 input gates in RTL compiler or DC. That's it...
Regards,
Eshwar
hi eshwar,
i think i confused u with my question.
i want the tool to make use of 3 input gates where ever possible, and also use 2 input gates.
thanks anyway for the reply.
Maybe you can modify the library so that the 2 input gates are undesirable? Or read in the library and use the set_lib_attribute to modify the area or timing attribute of the 2 input cells you don't want so the tool won't use those gates for it's implementation.
RC has a attribute called, set_prefered_cell or something similar .. search in command reference ... not sure about DC though ...
