i want to tap signals from the instrumentation panel ,i will use tapped signals for further processing.how can i tap signals without any effect to the panel.can anybody suggest best way to go it.example signals that i want to tap are Temperature,fuel. on panel this are connected to guages.
What do you mean by "tap signals" "tap temperature" ?
How do you want people to help you if you are giving no information on your hardware and what you are trying to achieve??!
My advises (very humbly)to you: 1)- give more details: what is panel? describe it. What is processing? which hardware (acquisition) and software (for really processing) do you have. How is the whole thing interconnect?
2) What did you try to do? what difficulties did you faced? describe them. Post schematics if it's not a confidential project.
I'm sure many people here are willing to help but with no information someone can't do nothing.
It depends on the type of sources driving the gauges. For instance, if the signals are ground referred current sources, you can insert small resistors in the loop and using a buffer amplifer pick up the voltage for further processing. If the signals are digital, may be you can use opto isolators to tap the signal. For ground referred voltage signals, again a buffer amplifier may be used. You have to design the signal tapping interface depending upon the characteristics of the signal sources driving the guages.
