fred3991
Member level 1
I'm trying to learn how to correctly calculate (cascade==RF system cascading) the connection of 2-port networks, taking into account mismatch losses. For example There is a first 2-port network, its S parameters at 10GHz,
And a second 2-port network.
They are shown in the pictures below. If you try to add them up as an RF system (!!!not adding S parameters via ABCD or T matrices!!!) - you have to add their insertion loss ((-0.577)+ (- 0.895) = -1.472 ). So the total insertion loss should be 1.472 - only if the 2-port networks themselves are matched by exactly 50 ohms (perfect impedance matching). But in fact, as you can see in the picture in ADS and ADSimRF - the insertion loss is 1.508.
My question is this. If I know the input and output impedance of the 2-port networks (s11 and s22 impedance on SmithChart) how do I need to account for mismatch losses to get the same results in ADS and ADSImRF ? I think I need to calculate the mismatch loss between port 1(50 ohms) - and the first 2-port network (46.999+j16.888), then between network 1(46.999+j16.888) and network 2 (55.2+j2.594) and finally between network 2(55.2+j2.594) and port 2.
I tried to use the formula
MismatchLosses = -10log(1-Г^2)
but either I calculated something wrong, or it does not fit.
I will be grateful for any help or advice
