How to store different values from a single variable into two variables
Brien Cheow
Newbie level 6
I need help on methods in which i can store 2 different values from my timer0 interrupt(number of overflows assigned to a single variable).
i have tried alot of different ways and i still cannot get it to work...
Please help me... Using Silicon Laboratory IDE interface.
bigdogguru
Administrator
Southwest, USA
Can you elaborate with a more detailed example, it's a bit unclear as to what you are attempting to accomplish.
Perhaps a structure or union typedef maybe a possible solution.
BigDog
milan.rajik
Banned
I will give you example based on PIC.
unsigned int x = 0;
unsigned int x  = (TMR1H << 8) | TMR1L;
xenos
Full Member level 4
unsigned x = ((unsigned)TMR1H)<<8 | TMR1L;
or
union {
          unsigned x;
          struct {
                 unsigned char lo,hi;
          } b;
} x;
x.b.lo = TMR1L;
x.b.hi = TMR1H;
Something like that?
milan.rajik
Banned
The title is wrong.
It should be
How to store different values from two variables into a single variable.
Brien Cheow
Newbie level 6
i dont really understand the mechanics of how to use union guys and milan the title is correct what i am trying to achieve here is to get the number of overflows at different intervals from my timer interrupt.
void timer0_interrupt_init()
    TMOD = 0x01;
  //  TR0 = 0;
    //TL0 = 0xEF;
	//TH0 = 0xD8;
	TR0 = 1;
    EA = 1;
    ET0 = 1;
 //  while(TF0==0);
   //TF0 = 0;
void timer0 (void) interrupt 1
    s++;
 // sp = &s;
    TL0 = 0xEF; //lower bit
	TH0 = 0xD8; //higher bit
    TF0 = 0;
milan.rajik
Banned
If you want to move TH0 and TL0 into one variable then you have to do like this.
unsigned int x = 0;
x  = (unsigned int)(TMR1H << 8) | TMR1L;
Brien Cheow
Newbie level 6
Milan again i am not trying to fuse anything ,instead what i want to do is get the int value s at different intervals and store it.
