How to start working on PowerPC
dariush
Member level 1
PowerPC
Hi
I want to work on PowerPc ,How can I start it ?
Does it have its instruction set? or its programs can be written by C?
thanks
dariush
zape
Full Member level 2
Spain
PowerPC
You can program in c, ada or whatever you want. It depends on your compiler.
dariush
Member level 1
Re: PowerPC
Hi
I want to know that C instructions for PPC is not diffirent from ordinary
C instructions ? if it is ,how can I learn more about them ?
thanks
dariush
javad
Member level 3
Re: PowerPC
OK! If I think your question really, I should say that C is a standard languege. So its instructions do not depend on machine you use.
I think you can use GCC compiler to compile your "standard" C code.
echo47
Advanced Member level 5
USA
PowerPC
Power-up a modern Apple Mac computer. Now you are using a PowerPC!
C is designed to insulate your from the CPU instruction set, so it's not a good way to learn about PowerPC.
Mountains of PowerPC info here:
https://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=018rH3bTdG
What's this? Motorola semiconductors is now Freescale? Oh good grief!
vomit
Full Member level 2
Re: PowerPC
Check out the Xilinx Virtex-II Pro, it has an FPGA with integrated PowerPC processor. The Embedded Development Kit from Xilinx contains all you need to program, in a very point-and-click fashion.
dll_embed
Re: PowerPC
Actually this is not a very relevant forum for your question. Anyway i'll try to contribute what i know.
PowerPC is a CPU structure joint developed by apple, IBM and motorola.
Like echo47 said, an Apple MAC is powered by powerpc. For embedded system, IBM and motorola(powerquicc, powerquiccII) are widely used in communication industry. To start you can get a eval board and play with it(There are plenty of them in the market). The most popular free compiler is gcc. Normally the vendor of eval board will give u all these cross tools.
The instruction set for PowerPC is free from IBM/Motorola web site. C programming has nothing to with that. Your compiler will take care the translation.
regards
dariush
Member level 1
Re: PowerPC
I read EDK document,I need some more examples about Xilkernel.
who can give me some refrences ?
