How to start with PLD world?
scorpionss22
Full Member level 2
pldworld
this is my second request to
howcan i learn pld
help me
to enter pld world
Re: second time no replyyyyyyyyy
You are asking a very broad question...
Try visiting the manufacturer's sites for tutorials and datasheets (Xilinx, Altera, etc) and using the search function here. There is also very much on the web, try this:
http://www.fpga4fun.com/
http://www.opencores.org/
In other words, read, read, read, think, design, build, debug, scrap, read more, think more, design, build, debug, etc etc. 8)
Cheers,
FoxyRick.
Hi scorpionss .. You sting!... I'm sorry buddy i missed your first request
Ok to learn PLD ..and later CPLD's wich are just bigs PLD Do this:
Get the data sheet of a PAL or a GAL .actually the PALs are almost extint now .A good starting point is the 22V10 ..
1)study the INPUT pin and PTERMS to a MACRO
2)study the CLOCK
3)study the MACROCELL and the OUTPUT pin
4)stydy the power consumption and tpd and other time parameters
Now after that you will be talking in terms of PROGRAMMABLE LOGIC
Now you need some PLD COMPILER is better to start with an assambler like PALASM,CUPL, ABEL or OTHER
the second phase is to learn how to describe COMBINATORIAL LOGIC
one tipical equation will be
A = /B*C*/D +.C*/F*+... (up to 8 to 10 Pterms .trying to fit more will result in a big ERROR ,which is your FAULT ) or other, so you need to affect output A to a particuliar pin number ( the sintax depends on the PLD assambler one example is :
PIN 1 B
PIN 2 C
PIN 3 F .....
PIN 19 A
PIN 20 VCC )
another usefull thing is to know how to TRISTATE
it may look like A.TRST = R*/S (up to 8 to 10 p)terms
Ok not to complicated so far ,you ALMOST KNOW EVERYTHING NOW!
Last PART . is SEQUENTIAL LOGIC
For that, what you learned studing the MACROCELL will help you here,to understand how to a clock a register using a CLOCK input or another TERM ...
Do a simple counter and you know everything
Last part is to undertand MEALLY and MOORE machines wich is another little page of reading ..
One great thing of dealing with PLD assambler is that you know righ there the time propagations and you can OPTIMEZE it as much as possible from the very beggining
CPLD are just more typical PLD blocks on the device .! Is then possible to use HDL languages .. Leaving the FITTER to allocate necessary resources at a extra cost of time propagation penalties
can you explain this!!!!!!
when i learned PIC i start with PIC16F84
i used:
1- assembly language for programming (which is the language supported from manufacturer in datasheet)
2-the COMPILER IS Mplab (which i download it from the manufacturer web free)
3- the programmer i found schematic in the internet web and i build it and it work
NOW THIS IS MY QUESTION:
1- i download the datasheet of 22V10 (so i will learn this PLD device)
2- what is the language which i must learn to program this PLD and where can i find good links to getting start
3- which COMPILER can i use and where can i find it
(please give me links)
4- the programmer where can i find it and is it free
direct links please
I HOPE YOU TO HELP ME AND PLEASE GIVE ME THE BEST CHOSE DEPEND ON YOUR EXPERIENCE
SORRY FOR THIS LONG POST
read datasheet,design a simple board for verify you code
u can use wincupl from atmel foe ur pld design needs.
u can also look for palASM, it is now in public domain.
both of them have many examples and documentations.
hock
HI scorpionss
Here ares some links :
PALASM :
WINCUPL :
resgister to download
http://www.atmel.com/products/pld/forms/softwareReg.asp
in general most manufaturers will offer some compiler solution
Here is Wincupl again :
do a serch on the INTERNET if you need more
search PALASM and WINCUPL
i used:
MPlab is not a compiler.
Compilers are not used for assembly language, but only for high-level languges such as C, C++ and BASIC.
A compiler translates the high-level language into low-level language (assembly).
MPlab is an assembler that translates assembly (low-level) language into machine code.
I have used ABEL to program PALs / GALs / PEELs, simple and easy to learn.
Hello scorpions22,
I believe you are thinking PAL has the same functionalities of a MCU. It's diferent. Usually the PAL just works as glue logic or some special features using combinatorial logic, you must think PAL like 74 or 40 CI series with spefic logic (ie A+B+NOT(C) ans so on). CPLD could be programed as state machine using more complex logic, could be use to process some signals, do simple criptografy etc. CPLD not works as MCU but in complement to. Please refer Xilinx apps notes.
FPGA could be used as MCU and uProcessor depends on programing. For FPGA you have HDLs that you program and "compile" (not exactly) your code before synthesize and download to chip.
In all cases design like a HW engineer, using digital logic, not like a SW thinking in therms of routines, classes etc. You can in these way produce a chip with good performance using a smaller FPGA.
