How to start learning ASIC designing ?
deepu_ttc
Member level 5
hello guys i am new to vlsi but i know verilog HDL but i never implemented.can any one tell me where to start and how to start learning ASIC designing i had a exp in embedded hardware ckt designing does it helps me in learning ASIC anywhere
--pradeep--
ankit12345
Banned
bangalore,India
beginner
Go through Brown book......
start working in lab...............Brown bok has a lot of examples which r simple........
just learning verilog is not enough.....u need to think verilog in terms of hardware.........so i recomend Brown book....its avil in edaboard
Other books prefer are samir palnitkar book..........
jsps
Member level 3
beginner
Digital Design by Moris Mano is good book.
and you can use Xilinx ISE WebPack & modelsim to simulate your programs. YOu can download the programs into chip using a programming kit
eesemi
Newbie level 2
Re: beginner
What is the full name of brown book?
for a beginner of asic, verilog is just a language, basic module and architecture may be more important.
chetanbs
Member level 2
Re: beginner
It is
Fundamentals of Digital Logic with Verilog Design by by Stephen Brown , Zvonko Vranesic.
It is a very good book which explains digital design with lots of examples.
Also you can try Advanced Digital Design With the Verilog HDL by Michael D Ciletti
which is quite exhaustive and very good
mssajwan
Full Member level 1
Banaglore
beginner
you can pic any book on verilog like palnitkar,bhaskar.
you can get these here in edaboard.
moreover i dont think embedded knowledge will help you. sound understanding of digital design is required.
-regards
-Manmohan
shiv_emf
Advanced Member level 2
beginner
for beginners, well digital design n CMOS logic design r must for understanding design flow ..
U must think in terms of hardware every time....
this must help u in ur sailing
regards
Shiv
viv_1005
Junior Member level 3
Re: beginner
You need to study the basics of digital design, starting from number systems, gates, muxes, shift registers, decoders etc. You also need to understand boolean theory, state machines, k-maps etc.
Then you can move to writing vhdl/verilog codes. If you have a background of embedded systems, then you must be used to writing software code. Hardware code writing requires entirely different thinking. So be aware of this.
All the best!
