charles007wong
Newbie level 3
Now I am doing on the project on the car. it have two motor to control the car movement. We using the MCU of AT89S53 to control the car. The power of the circult is separat from the motor power. We using the two pins of MCU connect to the motor driver SN74410 and the motor diver is then connect to a motor. To control the motor, MCU has to send signals through these two pins.
For example, MCU sends a high and a low signal through these two pins to the motor driver respectively, and then the motor driver will control the motor to rotation, say clock-wisely, and vice versa for these two pins changed to opposite polarity.
The speed of the motor is controlled by Pulse Width Modulation signal.
However, there have a lot of emf of the motor and the unstable voltage to let the car can not move forward.
Can anyone give some ideas to improve the movement of the car
Thx...
Thx...
