milan.rajik
Banned
- Joined
- Apr 1, 2013
- Messages
- 2,524
- Helped
- 540
- Reputation
- 1,078
- Reaction score
- 524
- Trophy points
- 1,393
- Activity points
- 0
I have written a Stepper Motor code but it is not working as expected.
My Stepper is a 12V Bi-Polar type. RPM is 360 and step angle is 1.8.
For full 360 rotation I need to step 360 / 1.8 = 200 steps.
In my project I only need to rotate +/- 90, +/- 180.
The motor rotates in these sequence
a) +90 and then -90
b) +90 and then +90 and than -180
c) -90 and then +90
d) -90 and then -90 and then +180
e) +180 and then -180
these sequences (a, b, c, d, e) can occur in any any random way that is...
if a occurs first then a, b, c, d, e can occur again
similarly
if b occurs first then again a, b, c, d, e can occur
The code I have written is given below.
I need 50 steps for 90 and -90 and 100 steps for 180 and -180 degrees.
It works fine for 90 and -90 but not for others.
I am saving the previous step executed in a static variable so that when the RUN_STEPPER() is called another time then previous step is executed again that is
there are 4 pulse sequence
0x10
0x40
0x20
0x80
as I am using upper 4 bits of PORTB
If previous pulse was 0x20 than in the previous step value will be 2 and next function call 0x20 is again executed first and stepper moves either in CW or CCW.
eg: lPreviousStep = 2
In next function call for direction 1 (CW)
lRequiredSteps will be 50 + 2 = 52
52 % 4 = 0
lSteps = lPreviousStep; (lStep will be assigned 2)
loops from 2 to 52 = 50 loops
lCurrStep = lSteps % 4; (loop 1st time, 2 % 4 = 2)
So case 2 of Step_Motor() is executed which is the same step which was executed as the last pulse sequence when RUN_STEPPER() was called previously.
But the code is working erratically. It turns 90 and then -90 and when it turns 180 again the angle is wrong.
a) +90 and then -90
c) -90 and then +90
similarly
0x10
0x40
0x20
0x80
52 % 4 = 0
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 void Step_Motor(unsigned char pStep) { unsigned char lStep = 0; lStep = pStep; switch(lStep) { case 0: STEPPER = (STEPPER & 0x0F) | 0x10; break; case 1: STEPPER = (STEPPER & 0x0F) | 0x40; break; case 2: STEPPER = (STEPPER & 0x0F) | 0x20; break; case 3: STEPPER = (STEPPER & 0x0F) | 0x80; break; } Delay50ms(); } void RUN_STEPPER(signed int pAngle) { signed int lAngle = 0; unsigned char lDir = 0, lCurrStep = 0, lRequiredSteps = 0, lSteps = 0; static unsigned char lPreviousStep; lAngle = pAngle; switch(lAngle) { case 90: lRequiredSteps = 50; lDir = 1; break; case -90: lRequiredSteps = 50; lDir = 2; break; case 180: lRequiredSteps = 100; lDir = 1; break; case -180: lRequiredSteps = 100; lDir = 2; break; }; switch(lDir) { case 1: lSteps = lPreviousStep; lRequiredSteps += lPreviousStep; while(lSteps <= (lRequiredSteps)) { lCurrStep = lSteps % 4; Step_Motor(lCurrStep); ++lSteps; } break; case 2: lRequiredSteps += (lPreviousStep + 2); while(lRequiredSteps >= (lPreviousStep + 2)) { lCurrStep = lRequiredSteps % 4; Step_Motor(lCurrStep); --lRequiredSteps; } break; }; lPreviousStep = lCurrStep; }
