How to solve the problem of loading wrong pll settings?
RF_man
Newbie level 6
Hello;
I am almost a newbie on Arm micros. I have a lpc2132 board and yesterday I accidentally loaded a wrong pll setting. After that, my jtag device refused to connect the micro. I heard that jtag didn't connect if I use a wrong pll setting and I had to load correct one manually.
The problem is that I dont know how to connect the microcontroller manually.
Any help will be welcome!!
Thanks
what happens if i use wrong pll
Hi
You will need to erase the micro flash using serial communication and a pc program like the FLASH MAGIC
then you will gain control via JTAG again
All the best
Bobi
