how to solve problem in cadence?
altra
Junior Member level 1
when I start my project manager in cadence ic5033, I find that I could not select the library.the system tell me this problem.I think something must be wrong about my configer.so ,could anyone can tell me how to settle the problem and how to setup ic5033 well in linux.
Log file is "/home/altra/libManager.log".
XtWarning
Class: XmTextField
Character '\146' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\165' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\156' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\143' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\164' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\151' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\157' not supported in font. Discarded.
XtWarning
Class: XmTextField
XtWarning
Class: XmTextField
Character '\141' not supported in font. Discarded.
XtWarning
Class: XmTextField
Character '\154' not supported in font. Discarded.
sup, I have the same problem, it has to be something with the fonts the icfb is loading, did you get to solve it yet??? any help from anyone would be geatly appreciated.
try put the following into your .cshrc file:
unsetenv LANG
unsetenv LANG
I have the same problem. And in cadence, I also have some button not work. Using your method ,it is working .
My question is :
If in bash shell,how to solve it.
And you have other method?
Thank you !
IN bash, you need to add the following:
unset LANG
in csh:
setenv LANG=C
in bash:
export LANG=C
or
LANG=C icfb &
unset LANG
Thank you for your reply, it is working .
Every time, before I use the Cadence, I input "unset LANG".
But I add "unset LANG" in .bashrc, it does not work.
Can you tell me why?
Added after 5 minutes:
Hughes said:
in csh:
setenv LANG=C
in bash:
export LANG=C
or
LANG=C icfb &
Thank you for your reply!
In terminal interface,I input "export LANG=C", it is working.
But I add "export LANG" in .bashrc, it does not work, Can you tell me why?
Thank you!
