Hi everyone,I had a question about "source" command in solaris 8
when I type the "source /xxxx/xxxxxxx/CSHRC/Cadence/.cshrc.cds5033"(if total characters is more than 49),I got an error message just like"warning: ridiculously long path truncated",I don't know how to resolve it.But when I tried it in another workstation,it works with no error.Faint.......
can anyone tell me what can i do with it.thanks a lot
You can use $echo $PATH to view your path environment variable.If your path is too long.then you can modify your .cshrc.cds5033.In this line"set path =( $CDS_HOME/tools/bin $path)",set like the following:set path ==( $CDS_HOME/tools/bin).only the first $path line!
Re: How to solve idiculously long path truncated in Solaris 8
You can try Long Path Tool. It deletes/unlocks, copies/renames path too long files/folders.
Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename.
Since in some instances, you may have experienced problems accessing, managing and even renaming files that have more than 255 characters, this utility has been made to answer this particular scenario. If you have also encountered problems like error messages that tell you that the path too long, too long path, destination path too long or cannot delete file then this program is definitely for you.
This will totally take place of Windows Explorer, Far Manager or other file managing utilities since this is maybe used in any type of Operating System even the earliest Windows 95 version.
