porschesun
Newbie level 2
I do know how to simulate the gm of a transistor by using deriv function. However, I wanna run the result of gmp+gmn vs Vicm. I can't use the above method because the current will be flat when the vicm reaches transition point.
It turns out that the gm will be zero when the slope of current is going to zero.
Does anyone help me solve this problem and run the right graph of this circuit.
Thank you,
Jason
Thank you,
Jason
