how to simulate the noise of op amps?
wonbef
Full Member level 3
Nanshan, Shenzhen
hi,all,
if use spectre simulator, how to simulate the noise of op amps? need your helps!
Thanks in advance.
all best wishes,
Add AC voltage source in series or current source in parallel.
there is noise or pnoise optional analysis in spectre analog artist
hi, extraord, in noise analysis, how to specify parameter options? thanks in advance.
if you use the simulation of spice
you can use command
.noise
the spice can give the noise voltage
Added after 2 minutes:
before use the command of .noise
must use the command of .ac
you can select the input from schematic or type \vin in blank.
and also the output like \voutp \voutn.
also the noise frequency such as 20~20kHz
for more you can search the doc in www.designers-guide.org.
How about in Hspice, and how to plot the noise waveform ?
Hi
In Spectre you have the Noise analyses - you have to place a port on the input and sweep a variable (probably frequency in your case).
You can also do this by runing a PSS analyses - this is more complex and you can apply 2 tones on the input.
You should be able to find tutorials and examples in Cadence Help!
Good luck!
many thanks to all above!
if place a port on the input, how to fill out the parameter option? thanks.
i had a try! in spectre, the result of simulation of using noise analysis between add a AC source and place a port on the input are different. i don't know anything wrong. if place a port on the input, how to fill out the parameter option? thanks.
regards
Who can tell me which kind of noise it is that is siumulated by the command .noise?
Thermal or flicker?
Thanks!
