how to simulate the gain and offset of dynamic comparator
rocky_
Newbie level 6
dynamic comparator introduction
hi,everyone!
I have designed a 10bit pipeline ADC, the sub-adc need many comparator as you know.I used the dynamic comparator to design it.
Now I want to know how to simulate the gain and offset of dynamic comparator?
Can anyone tell me the way?
Thanks!
Best reguards!
simulate comparator gain
you can use monte carlo simulation to get offset results.
Re: how to simulate the gain and offset of dynamic comparato
Any introduction to the method of running a monte carlo analysis? Does it need editing script file?
Hello,renwl:
Can you tell me how to do monte carlo simulation?
And can anyone tell me how to simulate the gain of dynamic comparator
The comparators usually use positive feedback, and if enough time is given they take any input and generate rail-to-rail output levels. So, it is not possible to define a "gain".
In what concerns the monte-carlo simulation you must define, for every element, the statistical variation of its parameters according to the information made available by the foundry - you should check the manual of the simulator you're using to see how to do this.
Regards.
You can use the method described in the paper I am attaching.
Hi
can you please provide more information on monte carlo setup for comparator offset simulation.
Thanks
could u tell how to run monte carlo simulation?
Not all comparator is positive feedback,and camparator can know the gain.
but u can post methode to simulate ota
thanks
