how to simulate slew rate of a fully differential op amp
bhargava834
Junior Member level 1
measuring slew rate fully differential opamp
I have designed a fully differential op amp. I do not know exactly how to measure the slew rate for a fully differential op amp. Generally for a single ended op amp we connect the op amp in non inverting(feed back) mode and measure the slew rate.
How to measure the slew rate in case of fully differential op amp??
Plz do reply.
Thanks & Regards
Bhargav Reddy
slew rate differential
similar to single output opamp. You have to set the gain and step input
slew-rate fully-differential opamp
Can u explain me in detail...
How the configuration looks like for a fully differential op amp to measure slew rate???
Thanks & Regards
Bhargav
