does anybody know how to see or simulate for the E-field ( maximum ) value for certain power input ( in watts - say 50W ) in HFSS for microstrip lines.i want to know the max. E-field and calculate breakdown power for a certain line.
Well, I guess someone can use fields calculator option in HFSS.. but how to find out exact solution for maximum power flowing through a particular surface is still to be figured out..
please help me if someone knows the solution...
I suspect the "edit sources" feature would let you inject a specific power at a port. Look into the manual or talk with an application engineer to be sure.
