I need to design a coplanar waveguide for proper microwave magnetic field urgently.
The basic configure is simple as below:
50 nm thick Gold (Au) CPW on Si substrate;
The gap and the signal line are 10 microns respectively, resulting in 1:1 ratio for 50 ohm impedance matching.
Focused on the distribution of the magnetic field parallel to the plane of the signal line.
I am still at the learning phase of HFSS. I 've drawn the structure as I described, but I failed to use the lumped port for excitation. Please help.
Many thanks!
