How to simulate FHX13LG in ADS momentum?
tony_lth
Advanced Member level 5
Beijing
I want to simulate FHX13LG in ADS momentum, what should I do?
I have LNA FHX13LG S-Parameters, and I can simulate in ADS schematic, now I want to simulate in ADS momentum, what should I do?
When I generate layout from schematic, in layout, there are three ref point for FHX13LG, do I need to draw pin PAD for it? Then simulate in momentum? Who can confirm it?
Thanks.
I made a simple amplifier using ATF36077 and got 11dB gain. But when I simulated with layout, I got -57dB gain, and found input is drain and output is gate, who can help me fix that problem to get proper gain in the layout simulate? thanks.
  • question1.zip
Your file is not a valid ADS project file.
Archive your project and post it here again..
Yes, you have to draw foot prints for electrodes of FHX13LG.
Yes.
You have to set port of referece point as ref points for FHX13LG in momentum setting,
then evaluate 3-ports s-parameters.
Using this 3-ports s-parameters and raw S-parameter of FHX13LG,
you can evaluate layout effects in s-parameter simulation.
---------- Post added at 13:48 ---------- Previous post was at 13:40 ----------
His archive is design file sets for ADS, s-parameter file and substare definition file for momentum.
Hi, Sirs,
attached is the whole project files, hope you can help me fix it.
Thank all of you.
  • Mom_test_prj.zip
Do you mean using Port3 to replace GND in the S2P file in ADS? Then get 3-ports S parameters. Then using it in Momentum.
Would you give some details?
Use this ADS project file..
You can not connect s-parameter defined models in MoM simulation directly.You should simulate your layout first and then you should put your model data file in a seperate schematic window.
  • Mom_test_prj.zip
