how to simulate differential inductor Q, L using sp analysis
lijulia
Member level 3
inductor differential q
Thanks!
how simulate a inductor
If you mean use S-parameter data it is easy. You may use almost any simulator. The easiest one is probably LINC2 from appliedmicrowave.com, next is Genesys from agilent.com. LINC2 is so inexpensive as so good that it is definitely the best RF simulator.
