SPSS ( Sweep Periodic Steady State) simulation will give you the bandwidth of your amplifier.
If you sweep the frequency, the amplifier will give you the peak power at certain frequency and then beyond that frequency (lower and upper) the output power will drop to -3dB of peak power.
These are your roughly bandwidth.
If you would, you can define this dropping as -6dB or more, all depends on you..
