You mean verilog simulation right? If so, then at the synthesis step where you generate the edf file, there should be an option to generate the equivalent verilog netlist too. After you get the netlist, compile it, along with the FPGA/ASIC library files. You can search this forum for post-synthesis simulation to get more info.
