I have no idea how to simulate a circuit with spectre. Is it similar to running the spice using a code rather than using a netlist from cadence or whatever? I can generate the netlist from Cadence (SpectreS). How can I use it for Spectre? what changes in formatting of model are needed? Please reply.
Thanks.
srivatsan
u can do simulation from analog artist .take care about your tech file settings and library settings.since cadence is a very big tool with lot of issues to take care.
well, i ran spectreS becoz i could know how to set the modelsin the appropriate format correctly. similarly if you can post the model format example for spectre simulator. i know how to work with cadence but not with model formats....
srivatsan
could someone upload allmodels.scs (or tell us where to get it from say for TSMC technology) because spectre uses this for models. I couldn't generate it (though I should be able to) from the main menu. thanks.
after your shcematic you should check for errors...if it no errors ..proceed ...
click on ADE ..some pop up will come ...from there you select simulator....after that load models........output to be selected .....analyses.......create netlist and run ................
