how to show message on PC when PIC interface with PC...
neo086
can the message show on the PC when PIC interface with PC via USART???
It can be done using microsoft HyperTerminal???
Yes you can write a program (example Visual Basic) to view the data coming from PIC and you can send the data to the PIC
Yes you can send and receive data using Hyper Terminal
Search the forum for more details
    V
can writting the code to pic to show the message ...jus like the code to show message in LCD ????
first you need to program at your PIC to send some character such as "Hello"..
then at computer (using Visual Basic) you need to program to receive it..
my advice, get yourself familiar with Visual Basic first...
can u send me some reference????thks a lot....
here your order sir....huhu
  • receive.zip
how to run a visual basic program by using pic....???
means to write a source code in pic microcontroller to open a visual basic program that is designed in PC...
pls giv me some references and examples of source code...
thks a lots...
No..you cant run that Visual Basic Source Code to pic..
Visual Basic is a software to create graphical user interface (GUI)..
or in easy way to explain, you are going to make your own software using visual basic..
the attachment that i gave to you is going to open with visual basic..like u open .doc file wit ms word..
so in your PIC program u just need to send data through uart..same way u send data to hyperterminal..
your means that i have to send data via uart to open the visual basic file or program created of visual basic???
pls giv me some example of references about how it can be done...
thks a lot....
