Register Log in
How to set_multicycle_path for latch in sta
CambridgeLv
Newbie level 5
set_multicycle_path -from latch/D -to latch/D seems not work
ThisIsNotSam
Advanced Member level 5
as long as there is a path between these two pins, it should work. after you issue the command, do a timing report from the same pin pair and check it.
CambridgeLv
Newbie level 5
After set_multicycle_path 2 -setup -from ... -to ... , it will return '1' which means success, but when report_timing of the 2 points, it still check timing in one cycle
ThisIsNotSam
I believe it means you missed something, maybe your from/to pair is not right. Also be aware that you can use wildcards if needed to capture multiple paths, say from signalA to arrayB[*]
oratie
Full Member level 5
Just curious: in your statement "set_multicycle_path -from latch/D -to latch/D" the first latch and the second latch are different instances or the same?
CambridgeLv
Newbie level 5
Different latch, sorry for making you confused.
CambridgeLv
Newbie level 5
I think there isn't matching problem, I have use this command many times for dff(edge-sensitive) with no problems. This is first time I use this command for latch (level-sensitive). Checking the Primetime guide, it says latch/D should be set in '-from' list, but it still doesn't work. I have no idea how to fix it.
ThisIsNotSam
can you post the timing report and the exact command you have used?
Toggle Sidebar
Design Fast
