How to set the ref designator for components?
taring77
Full Member level 2
power logic renumber
Hi all,
anyone knows how can i set the ref designator for components eg...instead of R1 becomes R101?
and C1 becomes C101??
thanks
Re: Power Logic Ref Des
use "renumber component" option, this is in the eco menu
fix the number which wher to begin
you dont remember to renuömber component after uğdate sch files
i tried to find but not so sure
..can u teach me step by step..thanks
Added after 6 minutes:
hi by the way i'm talking about fixing the schematic nothing to do with the PCB
i remember i did something that each time i added a capacitor in schematic page it becomes c101 automatically instead of C1
have to set somewhere..but can't remember
make insure that u have made change in schematic design ,
while running placement file delete previous parts ref designator
vij
its got something to do with the setting i did it in powerlogic 3.5.1
but now using PADs not sure if the setting is still available
using the following comments you can change the reference designator.
select part > query/modify part > rename part
